MEXICOWANDERER
May 18, 2018Explorer
Calculating your total -projected- load amperage should be your number one goal. Nothing appreciates be loaded to near 100% capacity. And there are few things nuttier than the thought of applying algorithm voltage changes to a static pure resistive load. Load goes up and down? Lights brighten then dim? Fan speed too?
An RV converter with an adjustable fixed voltage setting would work fine. Set it to 12.00 volts and be done with it. No Delta T compensation involved. Unless of course you have gone Wile E Coyote on the rig's accessories and overload the primary DC distribution circuits.
LEGIT QUESTION....criticize at your peril :)
What is the max D.C. hotel burden of the newer, largest luxury rigs? An inverter cannot be counted as hotel burden, thank you.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
