merc1100sc's avatar
merc1100sc
A/C Tripping Breaker Question
All,
I have a FR Work and Play with a rooftop AC. Not sure of the model off the top of my head but I don't think it's relevant at this point as I just want to confirm a few things.
Here goes. Last night, being 80 something degrees, I turned on the AC unit for the first time since I purchased this camper used. Kicked on right away and cooled very quickly. I then adjusted the thermostat up to make sure that works and turns the unit off. It did. Then, when I slid the thermostat back down, I could hear something in the unit spinning slowly for a few seconds. I assume the compressor. Then the A/C breaker inside the camper trips. If I reset the breaker, the unit fires back up and runs like normal.
After doing some reading, I think my issue is that the camper, in my driveway, is plugged into a standard receptacle, with an adapter cord, connected to the 50amp cable. I am guessing my issue is not with the a/c unit but with the corded and adapter being the bottle neck and causing the breaker to trip. Does this make sense?
And if so, will the unit run ok using my two Yamaha 2000W genny's paralleled together?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
