otrfun wrote:
LipschitzWrath, the LRA on your 15k unit is 79 amps. That's extremely high even for a 15k BTU RV unit. Most newer 15k units have a maximum LRA of 70 amps or less.
I was wondering that. For grins I logged onto the Coleman site and looked at the specs for what they spec as the new model replacement for what I have now. LRA (depending on where you look) is listed at 61 or 63 amps. Using 63 amps, that's literally a 20% reduction in LRA. Sounds like I am partially a victim of a big, inefficient, older AC unit. If I ever had to replace my rooftop unit, I'd definitely take advantage of the newer, more efficient model, but for now I am stuck with what I have.
otrfun wrote:
In any case, to put things into perspective, two EU2000i's operating properly in parallel (the EU2000i's are the king of inrush current BTW) cannot reliably start an RV a/c unit with an LRA much higher than ~60 amps---with the Eco mode on. With the Eco mode off, I've seen them start units with an LRA up to 70 amps or so. Never tested a parallel set of EU2000i's with an LRA much higher than 70 amps with the Eco mode off. IMO, it would be touch and go.
I'm glad you said that. For a while there, I was wondering if I had made a grave mistake going with the Yami's but from what you're saying, I would still be having this problem.
otrfun wrote:
FYI, from my experience, a simple hard-start kit may reduce the LRA 10 percent or so, or drop the LRA from 79 to 71 amps. 71 amps is still quite high.
Are you saying a factory hard start kit? Or an aftermarket kit (like the SPP6)? My AC came with the factory kit and I have confirmed that the capacitor is good. In any case, it sounds like I might have made the right decision skipping over the hard start kits and going straight to the Micro-Air.
otrfun wrote:
If your a/c unit works well on commercial power, all should be good with the MicroAir. The MA should easily drop your LRA down to less than 35 - 40 amps. Not sure about the Yamahas, but one EU2000i can start/run some newer, more efficient 15k units with the MA installed.
I only have 15A available at my current house so I dunno how well the AC works on commercial power. Never tried it. And we may never know. Sounds like the first time I will ever try the AC on shore power is when I haul it over to my father-in-law's house (he has 30A at his house) to do the MA "learn" sequence. I dunno what I'd do if it won't start on shore power with an MA installed. I'd lose it.
FWIW, I reached out to MA today and spoke to a very helpful individual by the name of Roger. He was happy to answer all my questions. He echoed what was said here. That is, the LRA on this AC unit is one of the highest he's seen. There is probably nothing wrong mechanically with anything (AC or generators), this is just a VERY demanding situation these generators are being placed in.
My 5er has the generator prep package and now I know why they spec'd an Onan 7kW 240V...
He said that the v2 models of generators from Yamaha are much closer to the Honda's in terms of surge capacity versus the v1's. Not saying better than the Honda's (I don't want anything to do with that debate), just better than the v1 Yamaha's.
He stated that his understanding was a 10% power loss from the generators for each 1000' elevation above sea level (I'm 6700'). Sounds a little high to me (I thought it was 10% per 2000') but okay. He recommended jetting the generators for high altitude. There seems to be mixed reviews about that on the internet. Some people say they're fine as is, others say do it. Any opinions here? If so, where do I get parts? The folks at Yamaha didn't see fit to package a nice "high altitude kit" like Honda does for their generators.
Lastly, Roger and I got to the meat and potatoes of the discussion. Based on my application, he said he would expect to see a surge of 23-25 amps on startup with the MA. He is 100% confident that it will work. I asked him very directly if he though the MA would allow me to start the AC with both Yamaha's in ECO mode (paralleled together, of course) and he didn't even hesitate - "Yes". With the 5-second delay on the MA and the pulsing it does during those 5 seconds, the generators will be brought up out of ECO mode before a compressor start is even attempted. He also said once the AC does start, he would expect the generators to quickly idle back down to whatever is necessary to keep the AC running.
After all this discussion, I must admit I am very excited. Should know more Monday night, hopefully.
FYI, the installation video that Micro-Air has on their website is EXACTLY the same for my installation, so I can follow it to a T. That said, Roger also stated that you can send an email to
[email protected] with your AC model number and they will send you a specific wiring diagram for your application.
Sorry to be so long-winded, I just wanted this information available for others if they are having similar issues.
