LipschitzWrath
Jul 11, 2017Explorer
1320Fastback wrote:
Mine does the same, one generator goes into overload and the other does not. It is always the same generator too that trips which is why i suspect the the cable.
My trailer is 30A wired but yes for 240V you will have one ground, one Neutral and two individual 120V wires.
One thing i am going to wire up is a Neutral Bond Plug for my generator. Basically it will tie the neutral and ground together as in a rv it is not. Dont know if it will make a difference.
Similar story here. It wasn't always the same generator for me, which is why I was changing which end of the cable is connected to which generator when the ends broke off.
If it's the same generator no matter what end of the cable is hooked up, I would suspect something with the generator instead of the cable.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
