LipschitzWrath
Jul 12, 2017Explorer
Alright. Update. Got my new parallel cable and generators are running good. Tried the AC right off the bat and got it to run. I was really grinning at this point but I knew that the real test would be cycling the compressor. I switched the AC off then back on, waited the required time, listened to the compressor come back on and... Overload.
I gradually started turning various other 110 loads off and trying again and again and again and I never could get it to fire. At one point, I have the converter, fridge, and any other 110 loads I could think of and it would still kick out.
At this point I decided to check the caps. Fan run cap tested low, but within 10% of nominal (7.0 uF actual vs 7.5 nominal). Compressor run capacitor also tested low, but within 10% of nominal (56.4 uF actual vs 60 nominal).
Compressor start capacitor, well, not so good. I will try to get pictures later tonight but it had a nominal value on the side of (47-56 MFD). I'm going to assume that is milli Farad? Or is that also micro? I tested it at 51 uF, so it kinda matters which one because it's either dead on or way off. The part number on it is 1497-090.
I will try to get pictures.
Edited to add - the start capacitor had a resistor across the terminals. I un-soldered it before taking these readings. Neither of the other two caps had resistors.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
