LipschitzWrath's avatar
Jul 10, 2017
AC Troubles - Hard Start cap? Something else?
Okay guys, new member, long time lurker.
The missus and I finally bought ourselves a 5er, a 2004 Terry Quantum Ax6. It's huge and we have had it out a couple times. Got a great deal on it and we love it.
Lately it's been getting hot enough that we want to use the AC and that's where the problems began. I am running two brand new Yamaha Ef2000isv2 generators in parallel (kinda), so I feel like I have enough juice. Other relevant details is I'm at 6500 feet elevation and the air condonitioning unit is a Coleman Mach 15k unit. My research indicates it has the factory start capacitor kit installed. Full model number is 8335b6764.
First let's clear up the generator thing. It appears I have a bad parallel cable that yamaha is doing a warranty on. The pins inside the cable broke off and I'm not sure I ever had true parallel capability. Maybe I did but everything I've been told is these generators shouldn't struggle at all to start this ac and I've been successful I think 2 out of 25 times.
Ideas? Could the factory capacitor be bad? Would adding an aftermarket (say spp6) cap help at all or is the factory set up about as good as you can do?
Do I need to get my refrigerant levels checked?
  • Glad to hear this worked out for you.
    I will get my MA wired in as I get other tasks done & will be testing to see if one of my EF2400is can run my 13K A/C.
    Gene
  • The reason for the larger size is there is a big capacitor inside the microair unit.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
