captdaveo's avatar
captdaveo
A/C turns on when heater activates
I have a Coleman Lantern 300 TQ. When I turn on the propane heater, the rooftop A/C unit turns on.
Why???? Doesn't seem to blow hot air.
I can trip the A/C circuit breaker to turn it off, and the heater then runs just fine.
I'm baffled, anyone have any insight?
  • As Carl_n_Susan said, there is a setting on the thermostat that is not on "auto".  I believe you go to the "fan" mode on the thermostat and make sure it is set to auto.
  • This happens when the fan (in heat mode) is set to anything other than AUTO.
  • Mine does the same thing. I just turn off the AC breaker off when I want heat.  I just assume the thermastat isn't smart enough to NOT turn the AC fan on when I wanted heat,
