MNtundraRet
May 04, 2013Navigator
Did you set the thermostat to the coldest setting?
Did you hear the compressor kick on?
How big is the generator?
It is certainly easy to hear the compressor over just the fan. If you have access to shore-power, I would check out the air-conditioner there first to rule out problems with the unit. If the compressor does not start, check for a tripped circuit breaker.
Now start up the generator and first check for 120v,ac, power. If the microwave will run you have 120v, ac, from the generator. No 120v,ac? check generator circuit breaker. Does your RV shore-power cord need to be plugged into generator outlet? My Fleetwood MH does. Made that mistake last spring, and took a while before I remembered that stupid mistake.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
