9274kks's avatar
9274kks
Ac unit problem ?
My 1998 32 Ft. bounder ,When the ac is in auto mode and you
turn the thermostat up it .Instead turning off the cool air
it turns on the floor heat .
    If you are not the original owner, then someone has rewired(miswired) the Control system. It should NEVER do that. Does the Floor Heat (furnace) ignite and get hot when this happens? It should if the furnace fan blower runs. Also, your wall Tstat, is it a RVP(Coelman) Or Dometic(duotherm) brand on it? IF NOT, then someone has installed an aftermarket home type Tstat and that is probably miswired. Doug
  • Kayteg1 wrote:
    Auto mode can do that.
    Do you have "cool"only option on thermostat?
    AUTO mode does NOT activate both the COOL and HEAT systems. It only activates when you select COOL mode or HEAT mode. ALL Auto does is allow the Fan to shut OFF when the Roof AC temp is met. Doug
  • Texas is famous for huge daily temperatures changes, but living at higher elevation in California, I can have 586F at 7 AM and 102F at 2 PM.
    So full auto makes sense unless you have well insulated house.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok, there are two meanings to AUTO.
    1: On my A/C "Auto" is an option on FAN SPEED. and that is what it controls.
    2: on some advanced Thermostats AUTO means "Automatic selection of heat or cool" and if it's cool, so you turn up the thing (increase the temp set point) you get heat.
    Sounds to me like working as designed,, Operator understanding error.
    I am from Michigan where this kind of thing would be real, real, handy don't you know.
  • Auto mode can do that.
  • j-d's avatar
    j-d
    Explorer II
    If your system is cooling, and you ask for a lot warmer than it is in the coach, I can see where the system would think you want heat. Normal, in other words...
    But do this, post make/model of A/C and Furnace and Thermostat. Ideally, pic of the 'stat. I doubt I can help you, but the odds of somebody else are much greater with specifics about the equipment involved.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
