mbrooks43
Apr 23, 2014Explorer
I have used the multi-meter to check the plug I use to connect the trailer to power. I can only get voltage through two connectors, which I believe is what I want. When I go into the breaker box, I was getting power between the black/white wires and black/ground (solid copper). I disconnected the ground from the incoming power wire and can still get power from the ground. I am wondering if one of the AC appliances is causing a problem, or the wiring to it is the issue.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
