donn0128
Apr 23, 2014Explorer II
You guaranteed have a grounding issue. If your using an adapter of some sort, that is the first place I would go. They are infamous for failing at the ground lug. Also check polarity of the receptacle your plugged into It is possible that it is wired back words or there is no ground there.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
