Gdetrailer
Apr 23, 2014Explorer III
mbrooks43 wrote:
I have used the multi-meter to check the plug I use to connect the trailer to power. I can only get voltage through two connectors, which I believe is what I want. When I go into the breaker box, I was getting power between the black/white wires and black/ground (solid copper). I disconnected the ground from the incoming power wire and can still get power from the ground. I am wondering if one of the AC appliances is causing a problem, or the wiring to it is the issue.
You need to get an outlet tester like THIS which indicates if you have open ground, reversed hot/neutral and normal (correct) wiring.
But you can use a multimeter by plugging in the meter into the ground and then plug the other lead into the wide slot (neutral), this should result in zero volts. If you get 120V then the outlet is miswired.
Keeping the one lead in the ground move to the narrow slot (HOT) you should get 120V if you didn't then outlet is miswired.
There is a possibility of an open ground on the trailer (or even outlet) which can allow the trailer frame and skin to be HOT from electrical leakage from bad appliances. One which does come to mind is the RV fridge heating element which is located on the fridge boiler tube. This element can go bad and create a electrical short to the ground connection..
You can verify by opening the fridge access panel and unplugging the fridge 120V cord. If hot problem goes away then the fridge heater is the problem.
Blown electric water heater element can also cause the frame to be hot also.
This is a dangerous situation so needless to say, do not use your camper until you find and fix this problem.. Unplug the shore cord, do not leave plugged in with this condition.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
