CA_Traveler
Apr 23, 2014Explorer III
Good to solve that problem. Use the three light tester to verify that the wiring in the rig is correct. Get one with a GFCI test button. Leave it plugged in. I've found 2 CG sites with reverse polarity. From your description you'll find a open ground which can be dangerous and must be fixed - not should but must.
Next plug the rig with adapter into a standard household GFCI. Turn appliances on and off to verify everything OK. Push the tester button to verify that the GFCI is working.
Then your done!
Then your done!
