dougrainer wrote:
MEXICOWANDERER wrote:
You mean to tell me the expansion valve on these units is not serviceable?
EVERYTHING on the AC is serviceable. Just not cost effective. Especially a 21 year old unit. Its a sealed system. By the time you install a line tap and drain/recover the Freon 22, then replace any Freon part, and evacuate and recharge, just not cost effective. Plus Freon depending on where you get it(now it is $75 lb) and just takes 1 lb. Doug
Clear and concise. Thank you. The folks who installed a new ND compressor, condenser expansion valve and evaporator on my toad, did something wrong and left it doing 50-50 pump cycles @ 15 seconds.
A year later it starts and runs for hours without fault. Cold as can be. The only thing I could come up with is that they overfilled the system which leaked down to permissible level.
