TravelinDog's avatar
TravelinDog
Explorer II
Aug 07, 2018
A/C works at night only
This may have already been covered somewhere so forgive me if it has.
My Coleman a/c which is 21 years old with very little use works great at night but when the temp is over 100 degrees in the daytime it blows cold for a few minutes then the compressor shuts of for a few minutes then come back on and starts blowing cold again.
It will do this over and over and never cool trailer down. I was thinking perhaps it is low on freon but I read that they are a closed and sealed system.
Could an rv tech check it if I took the unit to him?
  • time2roll wrote:
    What is the voltage in the RV? Low voltage is hard on the motor.
    Otherwise the cycling points to excess current through the compressor indicating the motor is about shot. At 21 years it would be OK to just replace the upper unit.
    Trailer is plugged into the house so I'm assuming it has the full 120 volts. It doesn't trip the breaker in the house or the trailer.
  • An R/V tech will tell you that you need a new A/C so be sure the guy you calls is also willing to replace it or you will have to pay a 2nd service call from someone who will. There's almost nothing to check other than to see if the fins are cleans and the inside filter is clean. If you can get on the roof you can do this yourself. You can't recharge the unit. There is a slim chance it could be the start capacitor but I don't think it would make any difference if it was hot or less hot outside.
  • What is the voltage in the RV? Low voltage is hard on the motor.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
