MrWizard
Jul 04, 2015Moderator
If you want it Only for backing up it should be connected to the backup lights line....aka the reverse switch
If you want rear view while driving, IT should be connected to ACC line coming from the ignition switch so it will be on when the key is on
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
