Chris_Bryant
Jul 06, 2015Explorer II
I would be tempted to throw a new ignition switch in there- should be under $50, if it's the basic dashboard (not steering column). The plugs that the switch plugs in to can go bad as well- there will be obvious signs of heat.
The ACC LPS appears to be an unused accessory lamp feed- I would assume it would be through the light switch, to light add on gauges and such. If it didn't have a fuse in it, I wouldn't worry about it.
You do need to get the camera system wired properly- should not really be a big deal.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
