kimberlysmoore
Oct 05, 2015Explorer
Chris Bryant wrote:
I would be tempted to throw a new ignition switch in there- should be under $50, if it's the basic dashboard (not steering column). The plugs that the switch plugs in to can go bad as well- there will be obvious signs of heat.
The ACC LPS appears to be an unused accessory lamp feed- I would assume it would be through the light switch, to light add on gauges and such. If it didn't have a fuse in it, I wouldn't worry about it.
You do need to get the camera system wired properly- should not really be a big deal.
Thank you and yes it is unused currently, as it turns out. Room for expansion, I guess. Cameras working great now. Still other issues. Slow and steady with everything.
I want to thank you for not telling me to move out of my rv :)
This is my life! I refuse to let go of being HOME FREE!
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
