pianotuna
Aug 27, 2016Nomad III
Hi pnichols,
I have two charging paths that I have manual control over. I went for very high amperage continuous duty solenoids which I have manual control over. My problem was fuses failing, so I switched to 50 amp automatic circuit breakers.
I do monitor voltage at the dash and at the house bank.
The specific gravity of the telecoms is 1.3 and the voltage is correspondingly higher. My starter battery is now 7 years old and is a Marine from Walmart. It's voltage is lower of course and the charging circuit sees that first.
When all my batteries were wally world marines I saw lots of charge flowing to the house batteries. That simply no longer happens unless I have a large load on the house--or if I have run them a long ways down.
pnichols wrote:
Don,
My Ford E450's 130 amp alternator every once in awhile spikes to over 60 amps (I saw 70 amps, once) when I run my two paralled ,12 volt 115 AH Group 31 Fullriver AGM coach batteries down too much. I monitor the Fullriver batteries while going down the road with a voltmeter and ammeter for them that I mounted on the cab dash.
I also have a voltmeter on the dash for the engine battery/alternator system. When this voltmeter does not closely match the coach batteries' voltmeter, I know that the alternator-to-coach-battery automatic interconnect solenoid is bad. This has happened twice to me, now, in 10 years. I hate arriving at a campsite to find that the coach batteries haven't been topped up by the alternator!
I prefer to keep an eye on things in order keep surprises to a minimum.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
