pianotuna
Aug 28, 2016Nomad III
Hi Niner,
How do you know they don't like high discharge rates? i.e. what are the symptoms you are seeing to make you believe that?
NinerBikes wrote:
They also do NOT like being taxed with high discharge rates, either. I try to keep the draw down to nothing more than 10 amps... try to take my showers in the morning when the sun is beating on the solar panel and the voltage is up a bit, let the solar panel make the electricity to run the water pump at a higher voltage and lower amperage draw.
I have a ham radio that at 100w will draw at 23 amps. The Telecom battery does NOT like that, so I usually limit my watts to 75 or 80w Tx. Listening Rx is a whole another matter, 2 to 3 amps listening or idling.
These are my observations, YMMV this is what works for me on 2 to 4 week camping trips dry camping.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
