pianotuna
Aug 29, 2016Nomad III
Hi Naio,
Yes, I do run the microwave from the inverter/battery bank.
But it represents a load of 160 amps and I have four twelve volt jars. So the load per cell is 40 amps. From a capacity point of view I have 556 amp-hours. So I'm loading at 28% of capacity when I use the microwave. Or c/3.5.
Run times tend to be short. For example, lunch today was a left over boneless pork chop sandwich heated in the microwave for 44 seconds (actually two 22 second runs). Two nights ago I had popcorn. Run time of 2 minutes and 22 seconds.
My biggest use, so far, was in June when I was being a "power pole princess" at an inadequately wired campground (is there any other kind?) I was forcing the Magnum into doing not just load support but voltage support. That meant drawing 64 amps from the battery bank for several hours. The numbers say 16 amps per cell. Or C/8.8.
I should never have to do voltage support now that I have the autoformer, and it will be automatic.
Naio wrote:pianotuna wrote:Do you actually use that on the batteries?
The worst load is the 1591 watt microwave.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
