pianotuna
Aug 29, 2016Nomad III
Hi Naio,
They used to weld by shorting out batteries. It was not so good for the batteries. Plates warp if you exceed their output capacity and it sure doesn't take long (as you found out the hard way).
Basically, you may have inadvertently "welded" the inside of the battery.
Naio wrote:
When I damaged a battery by pulling 2c from it for a second, I don't think it was because I drained the battery.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
