NinerBikes
Aug 29, 2016Explorer
pianotuna wrote:
Hi Niner,
How do you know they don't like high discharge rates? i.e. what are the symptoms you are seeing to make you believe that?NinerBikes wrote:
They also do NOT like being taxed with high discharge rates, either. I try to keep the draw down to nothing more than 10 amps... try to take my showers in the morning when the sun is beating on the solar panel and the voltage is up a bit, let the solar panel make the electricity to run the water pump at a higher voltage and lower amperage draw.
I have a ham radio that at 100w will draw at 23 amps. The Telecom battery does NOT like that, so I usually limit my watts to 75 or 80w Tx. Listening Rx is a whole another matter, 2 to 3 amps listening or idling.
These are my observations, YMMV this is what works for me on 2 to 4 week camping trips dry camping.
Stop and think about the chemistry involved. If you can recharge at 21 amps, and there is some energy lost in possible heat generation, then you are effectively saying the chemistry with VERY thick lead acid plates might actually take 18 or 19 amp per hour.
With that magical number of 18 or 19 amps, how do you expect the chemistry to allow you to discharge it at a faster rate than it will recharge? It flat out just won't. You'll try, but you'll see the voltage drop quickly. That's not good for the radio, the Transmit finals, or the chemistry of the battery or longevity either.... I don't know, it just seems like common sense to me? Blowing Tx finals is a very, very expensive lesson on a ham radio. I've no intention of trying to blue smoke a Yaesu FT-991 on a boon docking trip.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
