BFL13
Aug 29, 2016Explorer II
We had measurements and reports before on here that you could draw far more in amps from AGMs than with Wets (especially 6v Wets) for the voltage drop that would trigger the inverter alarm at 11v.
So the idea was (I thought!) :( that if you had a small rig that could only carry say two batts, but wanted to run a 2000w inverter to run the microwave, toaster, etc, you should make those two batts AGMs.
Now we are hearing you should not pull high amp draws from AGMs?
Which is it?
Which is it?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
