Hi Mr Wizard,
For everything except air conditioner use, 12 volt solar is quite adequate. Once you look at the wattage needed for roof air, it becomes clear that 48 is a winner, and 24 is barely viable.
Yes, I could replace the existing panels--but I'm limited by the Blue Sky 3024 di. In MPPT mode it doesn't "do" 30 amps.
What solar I do have appears to "out perform", and works in both leafy shade and rain.
I could stick with 12 volts and not replace the Magnum inverter charger, but unshaded space on the roof would not allow me to do much more wattage than I currently have. So I'd still be having an aluminum frame work added. I suspect that would cost as much as the new solar system--and goodness knows if it would be wise.
My cousin is a talented man, and has the equipment to weld aluminum, but, he is a perfectionist and will not do so.
If I intended to full time for another ten years--I'd be close to break even on costs. But more likely I'll go back to part time in 2019 or 2020.
My RV is only 2 inches under the legal limit for width, so hanging panels off the sides is not viable either.
Much as I hate the generator, I have it, and it is paid for. So I fear my choices, for hot days, are to be a "power pole princess" or a "gas guzzler generator head".
Today I'm a member of the PPP as the ambient temperatures is 89 f (31.6 c).
It is fun to dream.
MrWizard wrote:
Don
You could replace the unisolar panels with one of higher wattage
And parallel another controller if needed
I'm sure some body would but those unisolars from you
I already replaced two of mine last summer 2015,
And I'm considering replacing the rest of them
While 24v or 48v is in some ways appealing
I don't find it necessary in an RV
