xnizstudio
Aug 26, 2019Explorer
STBRetired wrote:
Monitors and thermostat run on 12V so should be fine. Potential is there that you burnt out the 120V fridge element, but with just a short duration, it might have survived.
EDIT: Check the electric element on your WH if it was on. Also check anything that runs off of a wall wart. Might have fried the wall wart itself.
Right now the converter is disconnected . There isn’t any way to check for power without the converter right ?
Like.. does the converter power all the electronics ? Can I plug the camper into the 110v outdoor socket without the converter connected ? What does the converter do aside from charge the battery ?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
