Bobbo
Aug 28, 2019Explorer III
allen8106 wrote:
A 50 amp RV does NOT like 220. A 50 amp RV has two 120 volt legs and is not 220.
There's a big difference.
This is one of the wrongest answers I have ever seen to any question. A 50 amp RV outlet is 120v/240v. Put a tester between L1 and L2 of any 50 amp pedestal and see, if you don't believe me.
Your S&B house is wired with 120v/240v. You use the 120v for lights, televisions, and stuff. You use the 240v for water heaters, stoves, and stuff. An RV is absolutely NO DIFFERENT. It uses the 120v for 120v stuff. If it has a 240v appliance, it uses the 240v. Most do not, but a few do.
