Wet_Coast
Jul 28, 2015Explorer
Are you charging at 14.8 volts?
I assume so, default output of the charger
How many hours in absorption?
Can’t tell, no display.
If you get down to 2 or 3 amps they are as full as they are going to get.
I have used the Xantrex and a cheesey Canadian Tire automatic charger, both showing “full”.
The MPPT external meter shows up to 90% and then falls back to 60 – 70% within an hour of disconnecting the charger.
I also have a 500amp shunt and digital meter, shows same voltages.
Are you verifying 100% with a quality hydrometer?
Going to get a hydrometer after work!
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
