GaryS1953's avatar
Dec 04, 2017
ADD ANOTHER SOLAR PANEL
Hi Everyone,
I currently have 2 165 watt 12 volt solar panels in series going to my Renogy MPPT controller. I have unobstructed real estate for one more panel and would like to add another. Ebay sent me a good offer for a 175 watt 12 volt panel. Would there be any problem adding that panel in series to the existing panels? I think by doing this I wouldn't get the extra 10 out of the 175 watt panel, but would there be any other difficulties?
I appreciate any input.
  • Check the specs, but you may exceed the allowable input voltage on your controller.
  • Not a problem. In series try to keep the amp ratings as close as possible. Your amperage @ 36+ volts will be the amps of the lowest amperage panel.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
