map40
Jul 16, 2019Explorer
1) You can use a 50 splitter, that would work great.
2) You can install an Atwood air command, it will work on a 15 amp plug on its own with no problem (I have 5 RVs configured like this and they have been running for 4 years as rentals)
3) You can install 2 Atwood air command or 2 Power Saver ACs and run them on the 30 amp. It will be tight, but it will work if you know how to manage them
Hope it helps.
Hope it helps.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
