MrWizard
Nov 16, 2020Moderator
My monitor is not a Trimetric,
It counts the Amp hrs removed from the capacity that has been set, it displays
Amp hrs remaining
% of capacity remaining
Battery voltage
Amp rate plus or minus
Wattage being used or charging
Has a low voltage protection setting, that can control a relay, use it for an alarm or use it to disconnect the battery bank, I do NOTuse that feature, but I might connect it to an alarm of some kind
It does not do a needless auto reset like the Trimetric, and I have never tried to do a minus count with it
And yes sometimes the next day after heavy night time inverter and MW use, the full capacity count reaches 100% and there are still amps charging,
So I just keep charging until the amps In, reach the correct value 2 amps or less for this bank,
In the summer needing the generator for the A/C
The charge rate often reaches 0.5 to Zero amps in aka saturation full level max attainable
Amp hrs remaining
Battery voltage
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
