j-d
Jul 24, 2014Explorer II
I think you will find that CAB/ANT is connected on the back side of your Winegard RV antenna plate. Assuming you have a crank-up batwing in addition to that dish... If you connect the bedroom TV to that terminal, it should do whatever the living area TV is doing. Batwing if Booster button is pressed and the LED is lit, CATV if you're connected to a site with Cable at your outside terminals.
Does AUX on that bedroom plate have correspondingly marked terminals anywhere else? At this point I can only guess. Fed from a second LNB on a Dish? From a DVD player somewhere in the coach?
I offer this based on my experience troubleshooting a Winnebago C where the cabling got all mis-connected by a well-meaning, expensive and incompetent "professional" and where our Jayco C had its rear bedroom cabling cobbed by a prior owner. You MAY be able to get a cabling diagram from the coach builder. Winegard's site has a diagram of the back of the Plate.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
