Bill_Satellite
Jul 24, 2014Explorer II
It sounds like you have a Dish dual Tuner receiver (DVR?). If so, that second remote control uses RF signals which go through the walls so you will be able to control the receiver from the bedroom just fine even while it's in the living room. You should have 2 outputs available from that receiver. HDMI from the receiver to the TV located near it and then a second coax output that you can connect to the living room wall plate and send the signal to the bedroom TV. The coax output is usually set to channel 60 as the factory default so once you have it all connected properly you will need to do a new channel scan on the bedroom TV to allow it to find the proper output channel. To watch satellite you just change the TV to channel 60 (or whichever) and then use the Dish remote to change channels.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
