GaryS1953's avatar
GaryS1953
Adding 3rd Solar Panel
Hi All - I currently have 2 12 volt 165 watt panels wired in series on the front part of the roof on our small 5th wheel camper. I have a 3rd panel with the same specs I'd like to install when the weather get's better here in Michigan, but I'm unsure of the best way to install it. The only available real estate for the 3rd panel is at the rear of the camper. I can envision scenario's where the rear will be in shade, but the front is not, and vice versa. I have a 40 amp MPPT controller, and I believe with only 3 panels I HAVE to wire in series, or change them all to parallel, but that would entail replacing existing wiring, and thicker wiring, 8 or 6 gauge rather than the 10 gauge I have now. My thought was maybe I could put in some sort of 3 way switch so that all panels would be connected, or just the front, or just the rear. Does that make sense, and if so, can anyone recommend a switch to accomplish it?
  • Almot's avatar
    Almot
    Explorer III
    Wire them in series with existing #10 cable and see if shaded panel bothers you too much.
    You have nothing to lose, just a short piece of MC4 extension cable, $10 worth.
    You only need big amps until it goes into Absorb stage.
  • “You only need big amps until it goes into Absorb stage.”
    Yes, Almot. A fact not understood by many RVers.
  • Almot, recommending #10 wire other than from one panel directly to a controller or to a combiner box just isn’t right.
  • The bypass rectifiers (a diode is a vacuum tube, why are they still called diodes - we don't call transistors triodes?) will take care of any shading issues, with only very minor power loss. Just wire them in series and don't worry, be happy.
  • GaryS1953 wrote:
    2oldman wrote:
    GaryS1953 wrote:
    Controller is a 40 AMP Renogy Tracer MPPT.
    According to what I find, that controller should be good to near 100v.
    Yeah,I knew the controller was adequate, just trying to prevent possible shading problems by maybe finding a way to isolate shaded panels.
    You only guessed! 12V panels are usually below 24Voc. Three panels in series is less than 72Voc.
    The MPPT will be good to go in series.
    I have 12V panels in parallel on my TT and in series on the van.
    HTH;
    John
  • Series will be the most shade tolerant, due to the bypass diodes. Installation is a slam dunk since you just add the third panel to the other two.
    Recommend you run the Morningstar String Calculator to make sure of your VOC at your low Michigan temps. But I suspect you'll be OK.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
