GULFMAN
Dec 22, 2016Explorer II
solar panels
Does anyone know if i can put 500 watts of solar on top of my 2500 9-6 Bigfoot
Thanks
Thanks
DWeikert wrote:
I put 400w worth of these panels ( Renogy 100W ) on my Northstar. Considering it's only a 7' wide camper and doesn't have the extended cabover, I'd be surprised if you can't get 500W on a Bigfoot. You may find it easier to use several smaller panels instead of finding the space for larger panels.
DWeikert wrote:work2much wrote:
On a sunny day there is no reason in my mind not to use solar energy to keep the icebox cold.
As long as you're aware just how little propane an absorption fridge actually uses. What you're investing to run the fridge during the day would buy enough propane to run the fridge for decades. If you were aware, go for it.
ticki2 wrote:DWeikert wrote:deltabravo wrote:HMS Beagle wrote:
I'm also curious as to why you would need 500. 200W seems to keep the batteries charged if there is sun, if no sun 500W won't either.
Ditto.
I have 300 watts on my AF, and it's overkill.
Amusing how some seem to think their personal example is typical for everyone.
If I didn't have a DC compressor fridge and a TV/satellite dish I would probably be fine with 100 watts worth of solar. But I do so I'm better with 400 watts. And yes, I get a charge from those panels even when it's cloudy. But I do get a lot more in full sun.
Apparently the OP is trying to run his 3 way fridge on 12v if he is drawing 15a just for the fridge , very inefficient .
Ditto.
Z-Peller wrote:You have just answered your own question... Thanks for making the point.
Ok, so by the same token were is it written that " this stuff is totally inacurate" ?....by who's authority is that?.....I happen to use the rule of thumb of 100w per 6v battery for my solar setup and it provides all the power I need...everyones needs are different as most people know....whats with the "authorative" statement that this is wrong?
Ditto.
