GaryS1953
Feb 12, 2018Nomad
Adding 3rd Solar Panel
Hi All - I currently have 2 12 volt 165 watt panels wired in series on the front part of the roof on our small 5th wheel camper.  I have a 3rd panel with the same specs I'd like to install when the weather get's better here in Michigan, but I'm unsure of the best way to install it.  The only available real estate for the 3rd panel is at the rear of the camper.  I can envision scenario's where the rear will be in shade, but the front is not, and vice versa.  I have a 40 amp MPPT controller, and I believe with only 3 panels I HAVE to wire in series, or change them all to parallel, but that would entail replacing existing wiring, and thicker wiring, 8 or 6 gauge rather than the 10 gauge I have now.  My thought was maybe I could put in some sort of 3 way switch so that all panels would be connected, or just the front, or just the rear.  Does that make sense, and if so, can anyone recommend a switch to accomplish it?
