SoundGuy
Sep 20, 2015Explorer
gbopp wrote:
Worst case scenario, you could just add a second thermostat to control the heat strip.
But, based on the above posts, the correct thermostat is available..
Problem solved. :)
Maybe, maybe not ... it would also depend on whether the wiring harness running from the A/C to the thermostat is suitable for also running that electric heating element. This wiring will have originally been installed as the coach was being built so running a different one through the walls and ceiling could be problematic after the fact. Rather than rely on forum WAGs the OP would be well advised to have an authorized dealer of whatever make / model A/C he owns contact the manufacturer with the model number, product number, and serial number of the A/C and ask what's involved.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
