Terryallan
Sep 20, 2015Explorer II
Golden_HVAC wrote:
Why?
The cost of the heat strip is normally well over $75 and a portable electric heater you can bring into the room you are located in, it is very quiet, and easy to replace for $20 - $25.
Also the noise from my air conditioner is a lot compared to my portable heaters. I have 3 of them, and use them mostly on low heat, blowing on me, so my feet are warm, or to heat up the bathroom just before using it.
Each heater has a thermostat, and is very compact. DO not buy the huge oil filled ones, or ones with a dome that has a glowing 200F coil on it. Those take to long to cool off before you can put them away. . .
Good luck,
Fred.
I agree with the Why? Heat strips do very little heating. Think hair dryer. Mostly a waste of money. The portable heater would make better sense. However. I do use the oil filled heaters. Silent, and good heat. Mine cools off while I dump the tanks. But if in a hurry could take longer than you want.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
