grizzzman
Apr 10, 2015Explorer
hammick wrote:
I called Renology about their 100w briefcase system and they told me that if I put a 100w panel in parallel with my 160w panel my 160w panel will attempt to match the power of the 100w panel effectively giving me 200 watts. Does this sound right?
I just did some quick research and it sound like the Renology tech doesn't understand parallel connections. He would be correct if I was going to connect a 160w panel and a 100w panel in series. Is my logic correct?
IIRC you are using a PWM controller if this is the case you will get 260 watts but...if you are using a MPPT controller he would be correct.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
