Almot
Apr 11, 2015Explorer III
grizzzman wrote:
How many solar charge controllers do you know that can run a bulk charge of 14.6 and when adsorb hits 3%of C20 it clamps the amps and goes into a finish absorb and allows volts rise to say 15.3 then holds it fom 0 to 4 hours? (User adjustable)
Or stop charging at a set amps? ...
I know one, and own it. Infinitely adjustable - timer based Absorption, current based, you name it. Without assistance of Trimetric. The only feature that I could possibly use in Trimetric, would be its been-counting function ;) - providing theoretical SOC based on AH in/out. Have figured out that, given the location, solar size and my energy use, I will have batteries full every evening anyway, so couldn't justify buying such a nice machine as Trimetric when there isn't much need.
So far so good. Not a solution for everybody, but then, solar isn't for everybody either. Wouldn't want bright Trimetric display in my room, they at Bogart should do something about it.
Yes, I wouldn't put a 30A controller in a sealed box. Maybe doable with smaller controllers and/or in climates not awfully hot and sunny.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
