Almot
Apr 11, 2015Explorer III
hammick wrote:
I thought you had to have the Trimetric to do any adjustment.
Nope. If CC itself allows adjustments of charging setpoints like timer, end-current etc, then you adjust it directly on CC. Normally, you set it as per battery manufacturer, and can further tweak if you "think", for example, that longer Abs or higher Float would positively affect the bottom line.
Trimetric monitor - like any monitor - is monitoring in-out flow at the battery. It tells you Amps and AH in/out. From what I understand, it can also "control" the CC if CC is by the same Bogart company, adding features that this CC on its own is incapable of.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
