time2roll
Oct 31, 2020Nomad
So you want to attach a portable cylinder rather than a second permanent mounted tank?
I agree with the extend-a-stay connection mentioned above. People often rent a 100# cylinder for extended camping when more propane is needed. Smaller 20#, 30#, 40# work perfectly fine too.
And at some point you do need to tap into the propane feed line to use the propane in the RV systems.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
