qwerty11's avatar
qwerty11
Adding a relay to lower the amperage on a switch?
I have these switches that are rated for 15 amps. The instructions say I can add a relay if I need to connect something that is over 15 amps. Could somebody help me understand what this means and link me to the relay I need for say a 30 amp load?
Thanks!
  • What this means is that the electric contacts in your switches are rated for a maximum of 15 amps. You can purchase a relay that is rated for higher amps. In that case, the switch would only activate the relay. The relay would act as the switch for the heavy amp draw item. I would think you could find a relay at an auto parts store. They come in many amp ratings. Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
