mitchmitchell16
Oct 02, 2019Explorer
Adding a second tank sensor display near the tank valves
When I flush the black tank (we have a tornado flusher installed) I will usually close the valve while the water is running so the black tank will fill. This allows the swirling action of the water to help pull out solids when I re-open the valve. Its a little risky, you have to avoid getting distracted while the tank valve is closed etc.
However, I have to keep asking my wife to check the tank display to insure I don't overfill the tank. What I am planning to try is to set up a second tank display on the outside near the flush valves in a small waterproof enclosure so I can monitor the tank levels myself when flushing.
Has anyone else ever tried this?
