drumming102
May 29, 2016Explorer
smkettner wrote:drumming102 wrote:Use the same size wire as the black and I would skip the fuse because you already have one at the battery. Looks like #6 but verify.smkettner wrote:
For 600 watts you want to use that connector on the lower left grouped with the black wire for your positive connection. Connect the negative at the ground bus.
So just go directly to the white and black comening into the panel from the batteries and put it's own fuse inline?
Since I'm only putting in a 600w inverter I won't be running additional wires. Way too big of a hassle with a sealed underbelly like mine for a small 600W inverter.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
