enblethen
Jan 11, 2018Nomad
I installed driving lights on my rig.
I bought a set of lights in a kit that I liked their looks.
I wired in a relay under the hood powered from my battery control center that had a driving light fuse. I used a small 30 amp relay available at local auto parts store. Any high amperage chassis battery location will work.
I wired a control circuit that is powered through the "run" position on igntion switch through an on/off lighted switch. I wanted the switch to be able to turn lights off when I wanted to. I don't like blinding people while parking in the dark at campgrounds.
Use adequately sized wire I used #14. Less voltage drop.
Fuse the power circuit
Fuse the control circuit
I chose ones similar to these.
LED driving lights
LED driving lights
