novi2some
Jan 12, 2017Explorer
Adding Driving Lights
I have a 2010 Fleetwood Bounder. I was thinking of adding driving lights.Has anyone done this? Just looking for pictures of how and where the lights were mounted.
[/img]I dont know if this would work on your motorhome, but on my gmc yukon I have a carr light wing (it is a license plate mounting bracket with ears on either side to mount lights) with 6" lights mounted on it. I have them wired through a relay to switch on with high beam. I got the lights used, but I believe they are from harbor frieght. I retrofitted yellow HID bulbs with 55 watt ballasts into them. The yellow HID light provides very good contrast in clear weather, and cut through rain like nothing else. In the past I have used KC 6" 150 watt sealed beam daylighters that also work very well, but they do not make the sealed beam anymore. The 130 watt KC lights do not work quite as well, but are good.wallynm wrote:
Should not admit this but will. The best additional driving light is a spot light on top of the motor home. In driving rain it works better than low beams or fog lights. On long roads at night like west of Socorro, NM or Clayton, NM you can use it to spot deer and other animals crossing in front of you or maybe just waiting to jump in front of you better than high beams.
Ours has a spot or flood setting. Always turn it off when I see lights in the distance.
