opnspaces
Sep 29, 2022Navigator III
I may be wrong but I don't think galvanic corrosion happens very fast.
I would probably buy a electric element and screw it into the tank. Then after 3 months turn off the water heater and let the tank cool. Then pull the element and see if you notice any corrosion on the threads. It none then screw the element back in and check again in another 3 months.
After your 6 months remove the element and put the plastic drain plug back in.
