sgfryeExplorerOct 19, 2018adding gfci outlet to inverter questionmy xantrex freedom xc 1200 inverter does not have factory installed ac outlet plugs. xantrex sells a gfci outlet as an accessory that can be installed in 1 end of the inverter by removing a plate an...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
Related ContentInverter Bad?Inverter installAdding Inverter/Charger.Questionsinverter questionTruck Camper adding inverter
