LoganhorseExplorerJan 18, 2021Adding Heat StripsWhat's the chances of being able to add heat strips to a B57915.711C0 with a control box of 3107541.009. Having a hard time locating anything on it.
cavieExplorerJan 19, 2021If you add heat strips you must add wire and breaker to carry the extra load of the strips. Also, thermostat to control them. Not a DIY job.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related Contentadding a heat stripAdding power outlets in slide with no wiringHeat stripChanging heat pump to heat stripDometic Heat Strip DMR702
